1 - 13 of 13 Posts
2016 Chevy Cruze Limited LT 1.4T
Publication Font Rectangle Number Tints and shades
Driving today, 84 degrees, slightly raining and normal humidity. I see the CEL turn on while my wife is driving, car is running normal. Strong. Any ideas off the bat??? Gas cap doesn’t look cracked or bad to me :/
Discussion Starter · #2 ·
Inspected the engine bay today and found that one of my air intake clamps broke and the filter was not fully on the hose/pipe. Hmmmmm.???
Well p0455 generally points to a bad purge valve when it comes to Chevy but i haven’t seen a bad one yet on the cruze. Doesn’t mean you don’t have a bad valve tho. You have any issues starting after pumping gas?
p0420 bad convertor but I would check 02 sensors first to make sure before replacing. I replaced my convertor about a year ago and it cost $800 from dealer.
Yeah I’m leaning towards a bad purge valve or bad gas cap myself, even though it doesn’t look faulty, can’t hurt to replace since it’s cheaper than an OEM Cat. Was dealing with this issue at the beginning of the year (P0420) and went ahead and replaced the PCV intake manifold and that took care of the code up until the last 2-3 weeks when the code has been coming back about a week later after I reset the CEL. Car is running good and MPG is the same. Temps are the same everywhere, all fluids are good, AC is good, electrical is all good. At the beginning of the year my trusty mechanic came to check out the cat for me and said it’s all good, haven’t had any issues with starting the car.
You can check the purge valve. Check the input side for constant vacuum. Or just replace it. They aren’t usually too expensive.
2014 Buick Encore Leather Ecotec 1.4 Turbo AWD
Yep. Replaced the purge valve in less than 15 minutes on my Encore. AC Delco was ~$32 on amazon.
Reactions: 1Point4Turbo
Yep. It is actually called Vapor Canister Purge Valve and the entire assembly with electrical and gas connections is replaced. It is also part of the PCV and emissions system.
Discussion Starter · #10 ·
thanks! Yeah I saw it was an entire assembly, got the part for cheap From Napa, just need to get to swapping it out tomorrow
Hopefully you bought the AC Delco part ?
1 - 13 of 13 Posts
