I have changed the thermostat 3 times. I still get p0597. Finally figured out that I’m not getting any ground from the blue wire that connects to the thermostat. So I rigged it so it grounds to the engine. Now the heater works but still get the code and sometimes it try’s to over heat but the fan kicks on. My questions is does it have to be grounded from the original blue wire from the harness that leads to the ecm or it shouldn’t matter? Or is it a an ecm issue? Yesterday it was also over heating and all the coolant started to evaporate from the reservoir and now that I refilled it the fan is stuck on. Any help?
Btw car is a 1.8 2015 car is salvage and was hit on the front driver side
