When I had these codes, I found that they would only set when the temperature was above 50 degrees F. With mine, the shutters were failing to open fully, therefore when they were staying closed 100% of the time at temps below 50, the code wouldn't set, then when the temps got high enough that the extra cooling was needed, the code shutters would open less than fully and set the code. If I reset the code in December, it might not set again until March, but if I reset the code in June, it would be back within 3-5 drive cycles.Well since I cleared the codes and they have not returned the dealer couldn't do anything. So next time I'll take it in with the light on, how ever long that will be. Seems to be fine, no light for a few hundred miles of driving, in town and on the interstate.
Yes I got itAnyone else with a diesel get these codes? Seems my active grill shutter actuator is bad from what I have read up on these codes. Anyone change out the actuator?
I have the P069E code in my 2014 diesel Cruze. It seems to stay clear in cold weather and return on warm days too.With mine, the shutters were failing to open fully, therefore when they were staying closed 100% of the time at temps below 50, the code wouldn't set, then when the temps got high enough that the extra cooling was needed, the code shutters would open less than fully and set the code.
In my case, I got under the car and found that the bottom-left corner of the casing around the shutters had popped open, preventing them from fully opening (probably during a previous car-deer collision). I squeezed it shut with a pair of channel locks and it has been good ever since. Not every case turns out to be that simple, though.
The active grille shutters are behind the lower grille in the bumper cover unless for some reason your car is missing them. That wire you describe sounds like the one that plugs into the active grille shutters. I can't remember for sure though. Here's a GM part # 94525972 for active grille shuttersI have the P069E code in my 2014 diesel Cruze. It seems to stay clear in cold weather and return on warm days too.
Where the heck is this assembly? What does it look like? Do I need to put it up on ramps and pop off the plastic under the front facia?
I also am missing the two plastic covers on the bottom corners of my bumper. The ambient sensor that should be on the left missing cover is hanging free by its wire taped up along with another connector. I don't know what that was supposed to plug into. Maybe its the plug to this mystery shutter thing?
