Hi, first post.
I purchased a 2011 eco manual trans car with ~100k early this year to commute in. Over the past 6 months I have put about 10k on with no real problems other than a slight pulsation of torque under load (never really figured that one out).
Anyway, last week I got a plethora of DTCs starting with lean left bank (don't remember number). Some searching led me to a faulty PCV valve. I replaced the valve cover, and also found that the check valve in the IM was missing, so I replaced that as well.
Last night after getting everything back together, I have
P098: IAT sensor 2 circuit high voltage
P0236: Turbocharger boost sensor performance
P0237: Turbocharger boost sensor circuit low voltage
P2227: Barometric pressure sensor performance
pins 2, 3 on the IAT connector both have 4.5V, which seems normal to me, and the live data shows ~80F.
Barometric and MAP both show ~28 inHg
What am I missing?
This is my first attempt to repair an OBDII vehicle. Your help is appreciated. I'm starting to pull my hair out here.:$#angry:
What am I missing?
