Welcome to the fun endeavor of changing out your parking brake cables! GM part number is 13352979.
Tools you'll need
- 1/4" ratchet
- 10mm socket
- 1/4" slotted screwdriver
- Linesmans pliers
- needle nose pliers
- A marker or plier ends
- Empty pickle jar
- Shoe box full of change
First we need the rear in the air, what we have here is a three stack of 3x3s with a 2' 2x4 as the ramp... it works.
You may be wondering "need I take my wheels off?" And the answer is, the 1/4" ratchet and socket fit perfectly between the wheel and stopper bracket. But to adjust everything properly, yes. I would of loved to do that but the out side temp was a crisp -17c / 0F
To unclip the cable end from the clip insert the 1/4" slot screwdriver and twist to pop the cable end out. Second comes the bracket held on by three 10mm bolts.
(Insert screw driver between cable end and the bottom of the clip)
Once the bracket is off the trailing arm there's one hanger on the chassis before it pops into the cabin under the rug. Best method I've found is to use the linesmens pliers to twist the plastic insert out of the holder.
At this point once everything is free it's mostly interior work now.
