Good day all,
My son has a 1.4, 2014 Cruz and the coolant neck is leaking... again. I've decided this time to buy this metal one from ZZP that folks have rec'ed, but I have question.
I want to also replace the clip-on hose that goes to the coolant recovery reservoir just for proactive reasons (I'm sick and tired of draining the coolant out of this thing to fix the leaks).
Can someone verify that this is indeed the correct hose before I place the order?
zzperformance.com
Thanks !
Engine Coolant Recovery Tank Hose - Cruze
This is an OEM replacement coolant recovery hose that runs from the water outlet on the driver side of the block to the coolant reservoir. The plastic fitting often breaks and will cause a leak. Fits: 2011-2016.5 Chevy Cruze 1.4L. Does not fit the 2016.5-2019 models with the 1.4 DI engine.
Thanks !
