1 - 4 of 4 Posts
My 2013 Cruze 1.4L turbo has an oil leak on the passenger side. It’s coming from the 2 bolts that goes through the motor mount and the tensioner pulley. Has anyone else had this problem?
Automotive tire Automotive exhaust Motor vehicle Automotive lighting Vehicle brake
Can I use some seleant on the bolt threads to keep the oil from seeping back through? Are those tty bolts?
One other question… the orange nipple in the pcv corrugated hose isn’t visible? Does this need to be replaced ?
Yes. They are torque to yield bolts.
The intake needs to be replaced or a fix kit installed if the check valve is gone.
You could try using sealant if you want too. Personally I would recommend replacing the timing cover gasket. Those bolts pass through the timing cover into the block. I'd be concerned that the sealant on the bolts would get into the timing chain.
1 - 4 of 4 Posts
