Reviving an old thread here, in hopes that someone in here has experienced this.
On my new-to-me '12 LTZ, with the passive entry sensors (not buttons), the entire passive entry system was turned off when I bought the car. It looks like it was since new, because the buttons on the key fobs are both fairly well worn.
I've turned the passive entry system back on and immediately experienced an issue with the driver's door. I reset all of the vehicle settings back to factory settings, which didn't help.
With the key in my pocket, I can tap my hand against either front door sensor and successfully lock the car.
Again with the key in my pocket, I can pull on any door handle of the locked car to unlock/open the door, EXCEPT THE DRIVER'S DOOR. The driver's door won't unlock like I don't have the key around. I've also tried with the key out of my pocket, in the same hand pulling on the handle or in my other hand, and it doesn't make a difference.
It seems like this is somehow broken for the driver's door handle only, although I can still lock all the doors from that handle, so it isn't completely dead. Right now, to get into the car, I pull on the rear door handle/open the driver's rear door passively, then close it, and then the driver's front door is unlocked so I can open it.
Has anyone experienced a partial failure at one handle only? Not sure if the 13503205 receiver would affect only part of the function.
Having had this feature on my old '12 LTZ, I remember how it should work, so operator error shouldn't be an issue lol.
