PCV valve cover
516 Views 6 Replies 4 Participants Last post by  Mechone1
I recently replaced the valve cover and intake manifold because of the common vacuum leak in the valve cover. I used the AM Dorman kit, I installed everything and it all went smoothly until the end when I went too replace the PCV hose, the main hose I replaced just fine but the tiny bypass hose that’s connected near the turbo I cannot find where it connects too and don’t remember where I disconnected it from the original intake. Could someone help me locate where it’s supposed to be plugged into?
1 - 7 of 7 Posts
I can’t Remeber where it connects too on the engine side, I have the main PCV hose connected. And I have the bypass hose connected near the turbo, but I cannot figure out where it connects on the engine side
It goes into a T fitting where the purge valve is IIRC.
I can check my cruze tomorrow as I have to wait for my property to dry up to go to the barn
I believe it connects underneath the intake manifold to the side of the inlet tunnels. There's small barbed fittings that connect to a rectangular block. Picture for reference of what to look for.
1 - 7 of 7 Posts
