1 - 2 of 2 Posts
Does anyone have a link where I can see a video of the replacement of the pcv valve
hose that runs right on the back side of the valve cover?
The part connected to the intake remove the metal clip with a pick, it will fully remove. Twist and pull up. If it's been on there for 8 years like mine, it does take some effort.
The other end of this hose I believe, but I have not done it is a squeeze pinch and pull, similar to the evap purge solenoid.
depending on how many heat cycles these connections have been through, they may break on removal. A new hose is around $30-$40 on amazon and Rockauto, and I believe Dorman also makes one, but if I recall they were all around the same price.
1 - 2 of 2 Posts
