These are two of my personal records for avg mpg and distance. The cruze I drive is more then capable of higher mpg avgs unfortunately I am limited by my terrain. I have 2500ft climb over 20 miles from 3000ft elevation to 5500ft which obviously is a disadvantage because I spend more fuel climbing the mountain then I save coming back down it. The rest of the terrain is flat and im able to maintain equal distance speeds of 63 and 53mph for a 58mph avg over the 625 miles. This spring and summer I should be able to average these same numbers between 56 and 59mpg on a daily basis over 350 miles. I think a 60 mpg avg is my limit for this route but definitely not the limit for the cruze eco. Phillips/Conoco 87 non ethanol only, Mobil1 extended perfomance, 40-41psi, 112k miles and 6th gear all the way.
The cruze I drive after all these miles in terms of the engine I can just feel how smooth and well oiled this machine has become. The engine I feel has really started to operate at such an efficient level and I think its better now after all these miles. Hopefully and I have my fingers crossed the engine will be able to maintain this optimal or peak performance another couple hundred thousand miles. As far as the transmission once the oil has a chance to warm up the shifting is very fluid.
Im not posting this for show I drive the same eco as everyone else instead im posting it for tell.
My engine is still breaking in (1,658 miles) but my best 50 mile stretch so far has been 47mpg according to the DIC.
I will try to set personal bests in tank averages and 50 mile trip on the upcoming road trips to Lordstown Ohio.
I already had my first oil change @ 1,250 miles | [email protected] psi cold | Shell 93 Octane | Spark Plugs .035 | Resonator Bypass
Which transmission oil do you use?
I replaced my transmission oil @ 105k with factory fill. A few bits and flakes but overall the oil was brown which is normal and healthy. I plan on making a routine of replacing the fluid every 50k. I also plan on using a magnetic transmission plug. I allready replaced my engine oil plug with a magnetic plug.
I think you are closer to the limits of how good the cruze eco/manual MPG is than you think. From what I have seen you are correct you will loose more MPG up hills than you gain coming down the back side of a hill, but its not an extreme amount of difference.
On a 500ft hill with equal proportions it's less than 1/2mile per gallon difference, usually I can remain extra easy on it for a few miles past the grade to gain back all I lost.
I don't know what my actual MPG was, but I averaged over 50 MPG for over 1,000 miles last June running at 55-65 MPG on an out & back route. I agree with spacedout that you are close to the ECO MT's theoretical maximum fuel economy, but I'm hoping you prove the two of us are wrong.
