I'd recommend looking into this... I had the same issues myself:Yes, I cleaned surface very well. I have not removed valve cover yet but I'm sure gasket either slipped or pinched in the top right corner. I can see oil leaking from that corner. The question is, how did that cause oil to go down to all cylinders?
Do you think replacing intake manifold now or at least cleaning the old one can help with oil going to cylinders?Unfortunately the valve cover seal will not cause oil to enter the piston.
I think you have a 2nd issue not diagnosed.
I've folded a couple of valve cover seals, always been able to re-seat it.
Only symptoms was spraying the engine bay with oil mist and a slight lean condition at idle.
My bet is PCV valve in the intake manifold. If you replaced it recently it can take a month for all the oil to get pushed threw the intake track.
Nope, I think the PCV is an underlying issue that is not more prominent with your better-sealed valve cover.I'm bit confused. Are you saying that bad valve cover gasket caused PCV valve to fail?
I had oil in my spark plugs holes and I believe it was due to the PCV failure in the intake manifold. Happened to me with a brand new, properly torqued valve cover assembly.If oil was in the wells, that just means the seal was leaking there as well.......clean and replace 'o' ring as needed.
Spark plug wells are dry as well as ignition coils. Oil is inside the cylinders. When I removed spark plugs all of the were wet with oil. I also fed borescope camera through each spark plug hole and saw oil on top of each piston (explains all the smoke from tailpipe).Woe there!
OP? Are you saying there was oil in the spark plug wells upon disassembly after the leakage was noted?
Or, are you saying oil was in the cylinders and burned onto the firing end of the plug.
I might add, clean any oil out of the bolt holes that hold the cover in place. Failure to do so will often result in a 'hydrolock' condition as you try to tighten the cover bolts. Since a liquid cannot be compressed, tightening the bolts will often result in the threads tearing out of the head.
To clean out the holes spray brake clean (wear eye protection) into each hole and either blow out the hole(s) with compressed air or a by blowing through a vacuum line directed into each hole.
I'm not going to talk about oil on the plug firing ends because I doubt if that was the case.
Keep in touch,
I found some oil residue under throttle body but I have not removed the pipe to inspect inside.If the PCV nipple is still there we can rule that out.
How much oil is pooling in front of the throttle body?
Turbo is really the only suspect. How many miles on the current turbo?
