Plasti dip fail
2732 Views 14 Replies 9 Participants Last post by  Blasirl
Ok so I went to plasti dip the chrome off of my 2014 LTZ RS. I took a bunch of time prepping and I even cleaned everything with acetone. Laid about four coats on every part and piece . Let it dry for 30 minutes between coat. When I went to peel off it was incredibly thin and difficult to get off. Not to mention it isn't breaking at the lines like it's supposed to. It's midnight here and I'm done. The grill needs redone and the right window trim needs redone. What am I doing wrong? Not waiting long enough before I peel it off. I thought this stuff is fool proof, I've been working on cars for at least 15 years. I'm so frustrated, time to crack a cold one and try to regroup. Any advice would be appreciated.
Sent from my iPhone using Tapatalk Pro
1 - 15 of 15 Posts
Ok so I did some reading and it seems that I may have made a big mistake. For starters I didn't have all the necessary tools. Didn't have an exacto knife to cut the areas that wouldn't break. And biggest of all I didn't wait 1-4 hours before I started peeling everything off. Can I salvage ''tis project and go back over the parts that are rolled and peeling or do I have to wait and peel every thing and start over? I swear YouTube makes everything look easy.
Helps to make sure the can of dip is fairly warm as well, and dip only needs to dry 10-15 mins between coats, and first 2-3 coats should be light and last 2-3 coats should be fairly wet coats. most people try to peel off excess before totally dry so that the good parts don't peel off, and be sure to over spray the edges a lot so that the excess comes off easier.
I would think, if your careful, you would be able to respray the piece of chrome showing and roll the peeled piece into the wet area and it might stick. Just a thought.
You basically just need to wait and then start over.
Yeah that's what I've been thinking too. I'm going to actually pull the window trim off and do it inside rather than on the car. I can't seem to find anything on how to remove the grill. Anyone know where that might be posted? A link would be great.
Good thinking on removing it. I can't imagine the grill is any harder than a few clips/tabs or screws.
I know when I used and I used tape to seal off the areas I didn't want painted I would remove the tape right after the last coat while it was still wet because the tape is a lot easier to get off while the plasti dip is still wet. If I waited for the plasti dip to dry and I pulled the tape off I usually took off a lot of the plasti dip off with it.
Removing the grill requires taking the front bumper off....
You need to do multiple wet coats. I normally do 4 coats on anything I do
Sent from my iPad using Tapatalk
This is not true. In can be done carefully with a plastic trim removing tool. The main grille is held in place with tabs. The upper closed grille is held with screws that can be accessed from lifting up the flat plastic thats mounted to the upper radiator support. The lower grille on my RS is also held by tabs.​
I need to do the same thing and was pondering that. If you do it before me, please post some pictures.
As far as the grill is concerned, here are a few pictures.
Automotive exterior Bumper Vehicle door Vehicle Car
Bumper Automotive exterior Vehicle door Automotive lighting Vehicle
Automotive exterior Bumper Trunk Vehicle Auto part
Finger Bumper Hand Vehicle door Automotive exterior
Bumper Automotive exterior Auto part Wallet
Bumper Automotive exterior Auto part Tire Automotive tire
Eco Cruze Fog Light Install--Warning: Lots of pics!!
Thats what i did too. invest in some good painters tape and use newspaper to cover the larger areas. take your time don't rush it!!
Just reading that again - honestly I wasn't drunk when I wrote it just tired lol.
What I was trying to say is I don't let the plasti-dip get too dry before I take the tape off. If I do I usually take a lot of the plasti-dip off with the tape.
Don't know where my head was when I wrote that comment. :blink:
:signs015::eek:ccasion14::stoner::eek:ccasion14::eek:hmy:
1 - 15 of 15 Posts
