1 - 2 of 2 Posts
Okay guys first day member here.
I’ve got a 2015 Chevy Cruze Lt with the 1.4 Turbo. I had to replace the valve cover gasket and valve cover. Now, it’s pushing oil out of the motor, I put 4 quarts in it and it’s looking like a rocket ship because of a constant white smoke coming out. It won’t go over 38 mph, and after about 2 minutes of running it says low oil pressure turn engine off.
where should I check first for the leak? The valve cover is fine and isn’t leaking.
Welcome Aboard!(y)
Read this:
1 - 2 of 2 Posts
