Welcome to CruzeTalk!
On my code reader the P0420, & P0496 say Permanent on them, I can’t clear them. I can clear the P0171 but it comes right back. The car died on me Friday night and would not restart, it just cranks. I installed the new Vapor canister purge solenoid Saturday morning but the car still will not start.Hello,
What codes is it giving you as of now? Did your repairs fix the codes it already had set?
Iv got a cheap code reader an if it’s ready right it shows the fuel pressure around 56psi when the key is in the ON position (i think I saw 75psi once)Do you have fuel pressure? If you can check that. Codes are for cat and evap so I dont see those keeping it from starting unless liquid fuel was getting by. Check the fuses for ign and fuel pump in the engine bay.
I checked the fuses for the injectors and they were good, Iv got a cheaper scan tool (launch Creader 4001) an it says ignition- spark. Does that mean it’s firing plugs?Can you verify the coil is getting 12v and is firing plugs? 56psi is ok for FP. Can you also check fuse for fuel injectors.
if your unsure how to check this just pull the coil and plugs. check the plug condition and gap, have a buddy crank while you check for spark the old school way. insert a plug into the coil and aim it some metal/ground. Ignition coil wiring schematics there's wiring schematics here if you have a voltmeter. test A/ (1st pin towards the front of the car) for 12v and B (next pin) for ground.I checked the fuses for the injectors and they were good, Iv got a cheaper scan tool (launch Creader 4001) an it says ignition- spark. Does that mean it’s firing plugs?
at any moment did you see "calc" on the information screen near the odo display? was the idle smooth? the valve cover is one of 3 pcv valves but if that isn't blown the others are most likely fine since it likes to blow out when the intake one fails. still best to confirm and rule everything out.When I got it to idle yesterday for 15min. I pulled the little plastic cover than clips on over the valve cover an can’t hear that pcv sucking air. And I covered the hole with my finger an couldn’t feel anything an there was no change in how it ran when I covered it
No Iv never seen “Calc” on the screen, I unplugged the battery on my lunch break today and it’s still unplugged. When I get home this evening I’ll try an start it an mess with the MAF. If I can get started again I’ll take pics of all the live readings of the A/F, etc, on my code reader so y’all can see if any Of the readings are”off”at any moment did you see "calc" on the information screen near the odo display? was the idle smooth? the valve cover is one of 3 pcv valves but if that isn't blown the others are most likely fine since it likes to blow out when the intake one fails. still best to confirm and rule everything out.
when i bought mine it was still running with intake and valve cover pcv blown and shot plugs among many other issues including a bad tps in the throttle body.
to me this def sounds likes a Air/Fuel ratio issue. you either have a massive air leak or the car is flooding fuel on startup which the reset may have reverted to default to get it to run. if you get it to no start again try unplugging the MAF sensor and see if it starts. also spraying some brake cleaner or use a bit of propane near where the intake meets the head.
okay I just reconnected the battery after leaving it unhooked over night and it won’t start. I then unplugged the MAF an still wouldn’t startat any moment did you see "calc" on the information screen near the odo display? was the idle smooth? the valve cover is one of 3 pcv valves but if that isn't blown the others are most likely fine since it likes to blow out when the intake one fails. still best to confirm and rule everything out.
.When you unhook the lines and stuff is there any liquid fuel?
