If one of the Moderators or Admins will be so kind as to go change it, "Yes," but I can't change it now.Question - can we go back and change our answer to the poll later? I'm currently marked as "Too early to tell."
My fuel economy goes down 3-4mpg for every tank that I have to use AC for at least 50% of the driving.My fuel economy is down 2 mpg, but I'm using the air conditioning now, so who knows?
So ... what gaps are people using in order to see this mileage improvement? I haven't messed with plug gaps yet, but DID notice improved mpg when switching from lowest octane available to highest octane available in my area ... about a 4-6 mpg increase, which more than pays for the extra 20 cents per gallon for the highest octane!2 mpg increase, as verified by the DIC and ScanGauge II. Went from 45 mpg DIC to 47 mpg. Same routes, similar/worse weather (using A/C more), and needing to play catch-up a few times. SGII went from 43 mpg to 45 mpg. It's there for me. Might not be as discernible for others.
That is definitely a pretty big difference!The wife was getting 35-36mpg now 38-40. Been 4 or 5 tanks through it.
...the OEM supplier (NGK) is supposed to be delivering them already pre-gapped to GM specifications; they are not being "gapped" individually as each one is installed in each engine on the production line.OK. This improper spark plug gap setting on many Cruze engines is a fantastic find. Now we should ask WHY spark plug gaps are not being set properly during engine assembly. One possibility is that time factors during assembly are being squeezed to the point that some assemblers are NOT gapping spark plugs properly, while in a hurry. Anyone have input into the seemingly simple ability to gap spark plugs properly?
Seems that experienced assemblers could almost visually see that spark plugs are not gapped properly between 0.025" & 0.035".
You bring up a point now that I am trying to get to. Yes, I'm sure plugs are being pre-gapped & probably accurately to GM specs. I think after the plugs are placed in their boxes & shipped, the jouseling & banging they are receiving might be tapping the plugs down to under 0.3". I would think that plugs should be gapped by the assembler himself or as you say, a pre-assembler, while on the line....the OEM supplier (NGK) is supposed to be delivering them already pre-gapped to GM specifications; they are not being "gapped" individually as each one is installed in each engine on the production line.
