1 - 4 of 4 Posts
I am having a hard time tracking down a popping sound from my front driver side wheel area, and reading a lot that sounds similar but nothing that's fixed it yet. The sound only happens when the brakes are warmed up (after a hand full of miles), and applying brakes. If I let off, the sound immediately stops. It is a repetitive popping sound about once per tire revolution. It happens at all brake levels, but much more pronounced when lightly braking and coming to a slow stop. It also happens at all speeds (after being warm). As soon as you let off the brake pedal the sound stops.
I have cleaned and lubricated the brakes and calipers, guide pins, all brake hardware as best I can. The pads have 20k miles on them and about 1 year (AC Delco OEM replacements). Rotors were also changed at the same time. I have replaced the sway bar end links with moog links about 90k miles ago. Vehicle has 120k total miles.
I do not believe it is the strut, and the bearing passes the 6-12 o'clock shake test. I will look at the lower control arm soon in case the ball joint/bushings is the culprit. Is there a way to check the CV joint that doesn't involve removing it?
Any help is much appreciated.
Are your brake pads secure in the slots? (don't know the technical term sorry). Could be that the pad is a tad loose and the unevenness of the rotor is causing it to move and slap within the slots?
Just a thought. :D
1 - 4 of 4 Posts
