You have to remove it as there are air dams at the end of each intake runner.
Yes, definitely a little low end loss I think, better high end though. Intake manifold spacer brings some low and a lot more mid. Probably 10hp gain, you can feel it though.How much power is to be gained from this? Does this take away low end response for high end HP?
I think you answered your own question in the last sentence. You get more airflow so the computer sends more fuel. More fuel and air equals more power.Won't the engine computers adjust the air/fuel ratio to certain parameters anyway ? IOW, when you add more airflow, the computer adjust fuel and vice/versa so you really don't get more power.
I take that off after I unbolt the manifold. It’s plenty long enough.Removal is simple enough just take your time, the hardest hose to remove is a 1/4" vaccuum line that is connected directly on the bottom of the manifold itself but could be done with some skinny hands lol
really? on my 2011 I only have about 2-4 inches of slack from/to the front of the carI take that off after I unbolt the manifold. It’s plenty long enough.
No. I didn't say it sends more fuel or more air. I said it adjusts to what it is getting. You will wind up with the same output. Tuned is different. Stock tune can't be fooled simply by adding more air or more fuel.I think you answered your own question in the last sentence. You get more airflow so the computer sends more fuel. More fuel and air equals more power.
"when you add more airflow, the computer adjust fuel and vice/versa so you really don't get more power."No. I didn't say it sends more fuel or more air. I said it adjusts to what it is getting. You will wind up with the same output. Tuned is different. Stock tune can't be fooled simply by adding more air or more fuel.
