1 - 18 of 18 Posts
I've been fighting my 2011 1.4 L Turbo engine ever since my wife hit a deer a couple years ago.
I've replaced hoses, gaskets and everything else running around this engine and been still dealing with the same issues and it slowly but surely continued to get worse leaking coolant and overheating.
Last week my wife was driving it and she said it didn't initially want to turn over but did after a 2nd attempt then after 10 minutes of driving it was idleing lower than usual and from her description it lope-ing between low and normal (like chugging I guess) it had major power loss upon acceleration flashed the stabilitrak/traction control bs and a cloud of white smoke blew out the back of the exhaust. Sure enough thinking well there goes the head gasket checked the oil but it didn't have that milky color from coolant being mixed in with the oil. Every time I look or think about it I just I get that awesome hot feeling and feel my blood pressure start to skyrocket so I've left it parked and sitting since.
Obviously the best thing to do would be to take it to a shop but atm I'm trying to determine if its worth even fixing at this point with the amount of the costs of repairs to the value of the car.
I'm pretty mechanically inclined and would be all for fixing it myself but I haven't been able to find the information I've needed to break down the engine and rebuild it let alone finding out I'll need a special cam tool that is made specifically for this engine. Then from what I'm reading re-timing is hell and then some along with some things I'm reading saying it could all be the turbo and not the engine. So I have no clue.
Thoughts, opinions and links are all greatly appreciated. I'm just trying to figure out what to do.
Worst comes to worst I'll end up parking it until I can transplant a 350 V-8 in it so if all else fails at least I don't plan on scrapping it or burning it to the ground.
I'm exactly where you are at. Just got the cam locking kit and I'm going to give the head gaskets removal a shot. Looked for an engine swap, but I'm not sure I can handle that.
Cool talk guys
It’s a forum not a 24/7 help desk...
You dont need coolant and oil mixing to have a head gasket leak. have you checked the compression on the cylinders? This could very well be a turbo issue. Any codes show up with a scan?
I never used a special cam tool since I couldn’t find it. I made my own custom cam lock tool from metal bought from Home Depot.
Someone else's post suggested that you don't get that with Dexcool mixing with synthetic oil.
I'd do some other tests for head gasket.
Any idea if a bad turbo would bubble coolant in the reservoir or is that coming from a bad head gasket? Guess I need to buy a cylinder test Gage..or do I need a leak down test kit?
I wouldn't think the turbo has enough pressure to force air into the cooling system.
I'd think the test you want is compression test, but I could be wrong.
Reactions: Kf-bg
that's more than likely a blown head gasket. Simply pressurize a cylinder once its at top dead center....pop the coolant tank cap off and see if it bubbles. All you need is 100 or so psi...start there and then slowly bump it up to 150psi.
We have a 2015 Cruze ... ran hot... now blowing into coolant... and I believe out the exhaust. About to purchase a compression kit but pretty sure it is a head gasket. I have acquired another cruze which was totaled, engine supposedly good.
What are your experiences with pulling the head? Typical gasket issue? block issue? Replace head? Use dynamite? Issues with remove the head?
Thanks much!
Thanks much!
head might be too warped to fix. I bought a "blown head gasket" motor and machine shop said it was too warped to resurface. Its really easy to remove the head, just gotta have the right tools to r&r. You'll need new head bolts too.
I just went thro and felt the same as u about the Cruze. I replaced head gasket. It was a pain. I got tons of info online but the experience is where u learn a lot more. The timing kit u can get keeps it in time so u don’t have to mess with it being out of time.
Thanks much!
Get timing tool from amazon to keep it in time while taking off head. Be prepared to order a few parts if it’s the first time doing a head gasket replacement. It’s not an easy job but patience is key. Done mine and learned a lot.
1 - 18 of 18 Posts
