A friend of mine has a 2012 Cruze that supposedly has a 2016 engine put in it which stopped running a couple months back. I came over and it would crank but not start, fuel relay clicked but no noise from fuel pump. We went and got a pressure tester and there was absolutely no pressure with key on or when it was cranked. We replaced the fuel pump, got everything put back together, and when turn the key to accessory all of his service intervals and dashboard menu information is just dislaying dashes. When you try to start the car the headlights and dash go dark. No crank. It's like the car loses all electric, but all we did with the electrical was disconnected the battery when we replaced the pump. I thought it might be the security system but the guides we followed to disable it did not work. Any ideas?
