Status
Not open for further replies.
21 - 40 of 89 Posts
· Banned
Discussion Starter · #21 ·
I see the rims but I don't see any that match the cruze bolt pattern. Am I missing something?
The Cruze uses a standard 5 bolt pattern. These rims are 100 - 114mm universal PCD. So they fit. ALTHOUGH. They DO NOT Fit 100% concentric. Thus they produce a noticable vibration at about 100 Kmph. But we have a solution for these things as well. A simple sleeve, machined precisely to fit between the rims and wheel hubs. This ensures 99.99% accuracy = Stock accuracy. Thus You can achieve a perfect fit. So incase you put rims, make sure you have a sleeve between the Rims and your wheel hub to avoid vibrations between 100 to 105 kmph, and also to avoid screwing your wheel bearings. Once you have the sleeve in place, its all set and nothing to worry about :D
Cheers
Hemank
· Banned
Discussion Starter · #22 ·
How does one control the SatNav unit? Is it touchscreen or is it controlled just like the factory installed SatNav through the button controls below the screen?
It is a touch screen indeed. I will upload high res photos of the same unit soon. I see a lot of interest on this forum. Will do it soon.
· Banned
Discussion Starter · #23 · (Edited)
so this changes the actual radio itself or is it just a upgraded screen? This sounds great just a little leary of changing something like that with an unknown product. I would like to see directions on installing this. I would love to see and hear from people that get this installed..
You have two options:
bigger screen than the one avaliable in the ECO model, along with an additional DVD player to be mounted in the glove box.
Advantages : You can still play from your 6 cd changer as well as the DVD player
Drawbacks: Additional space occupied for storing the DVD player
Or an entire unit from the Screen all the way till the CD player section. (The DVD player replaces your existing CD player).
Advantages: No additional space req.
Drawbacks: You lose a 6 CD changer and get only one DVD player.
That is the screen available here even in the top end models. So we sell a lot here. Our product has been fitted on multiple Cruze's without problems so far. It is safe and does not void your warranty, as there is no wire being CUT. Its a plug and play unit with safety cut offs.
· Lyrical Wordsmith
If you don't mind. You think you can upload the DIY manual? Also pics of the module itself?
Do you have any pictures of it installed in an Eco model? Also, do you have any US distributors who can vouch for your company?
:) Thanks. I assure you amazing light too. IF you would like I could ask my sales team to send you a Pair along with a DIY Manual. It costs only 160$ + Shipping.
So it's a DIY projection kit? I'm thinking so, otherwise I'd think the price would be much higher. When it comes to stuff like this, I'm not much of a DIY type of person...:eek:
· Banned
Discussion Starter · #30 ·
I can send you completely assembled headlamps as well. But that will naturally be more expensive.
· Banned
Discussion Starter · #31 ·
Pictures of the Headlights, Satnav, Filters or mufflers? I have uploaded pictures of My 2.0L Diesel cruze fitted with Headlights and the In-Dash stock replacement SatNav system with Can Bus interface on the first page.
· Banned
Discussion Starter · #32 ·
I do not have any dealership in the US as of now. But I would like to expand soon. If you are willing to re-sale my products, we can talk business :p
Sorry, I was talking about the in dash unit. Does it keep the stock appearance? Do the hard buttons do anything after installation? Will my steering wheel buttons still work?
I would consider it depending on the terms, however quality and reliability of the manufacturer is most important. I work in retail and B2B sales and I won't commit to selling anything without using it first!
· Banned
Discussion Starter · #35 ·
Ok Let me brief you on this.
First of all. Your Car WILL look stock. And very nice too.
When you start it, and your radio/CD/DVD/Satnav is off, you will see the clock (shown in one of my images).
Once its powered on, with the standard power s/w, you can use all standard functions that exist in your vehicle at the moment through the normal buttons you use at the moment. (The buttons on the dashboard and on the steering wheel). These all will generate a translucent 'pop-up' that basically shows what you would see on your current screen. (Check in one of the images). You can minimize the pop up any time and use the following functions by the touch screen:
Navigation options
Bluetooth connectivity and phone call answer and reject
DVD Video
E-book
Settings.
You can also control the USB and MMC through the touch screen.
I hope its clear.
· Banned
Discussion Starter · #36 ·
I could send you one piece as a Sample. You can use it and test it the Way you like. Then probably after you're satisfied, we can work out a Deal.
Sat Nav + Bluetooth phone audio connectivity, + Photo viewer + Dvd + Audio Cd's (Ofcourse) + MMC + USB + compatible with the existing CAN BUS and displays all the original features in a small translucent Pop Up. + Rear view Camera attachment possible
18 Months Warranty.
Price : 350 USD + shipping.
In-Dash stock replacement system with the above mentioned features: 520$ + Shipping with 18 months warranty.
Well which one is it? 350 or 520?
21 - 40 of 89 Posts
Status
