Are saying you are using wheels that are the wrong bolt pattern and adding hub centric rings to help center the wheel and that's all?The Cruze uses a standard 5 bolt pattern. These rims are 100 - 114mm universal PCD. So they fit. ALTHOUGH. They DO NOT Fit 100% concentric. Thus they produce a noticable vibration at about 100 Kmph. But we have a solution for these things as well. A simple sleeve, machined precisely to fit between the rims and wheel hubs. This ensures 99.99% accuracy = Stock accuracy. Thus You can achieve a perfect fit. So incase you put rims, make sure you have a sleeve between the Rims and your wheel hub to avoid vibrations between 100 to 105 kmph, and also to avoid screwing your wheel bearings. Once you have the sleeve in place, its all set and nothing to worry about![]()
Cheers
Hemank
