1 - 13 of 13 Posts
I have a Chevy Cruze 2014, with 99676 miles that had a issue with water coming in on the passenger side right under the air bag. The following day I noticed that the radio was off and the turn signal is silent but the car still drive.
I am suspecting that the water issue might be due to the black cover ( picture attached) that might need to be sealed? Any thoughts concerning the radio issue?
Car Vehicle Gear shift Automotive design Motor vehicle
Vehicle Car Speedometer Trip computer Motor vehicle
Automotive tire Automotive lighting Car Vehicle Bumper
Motor vehicle Automotive design Automotive fuel system Hood Vehicle door
Try to open and check the instrument fuse panel located located in the instrument panel on the driver side, back under the cover to the left of the steering wheel. Check for any wet, wipe and dry any traces of water. check or replace the fuse number 4. if it works, fix the root cause of the water leak. Maybe a bad windshield seal or something.
Rectangle Font Parallel Diagram Engineering
I did the continuity test on the fuse 4 & 5, they are good, fuse 4 is a 20A and fuse5 is a 7.5A.
I am contemplating to go with an aftermarket radio( touch screen Android 11,...). Does the radio require to be reprogram for the VIN?
2nd 2012 1.8l mt 147000km
Dude, my dude. Ohh my man pic #4 that little flapper thing is the windshield cowling drain / if you park under a tree a leaf n dirt collector.
Gentle pressure or inserting a slotted screw driver with gentle pressure to tension the little plastic pivot tabs back to remove the cap.
Door chime, alerts and warnings all work through the radio via the drivers side door speaker.
@Cruzing12, just to clarify you meant the picture below
Shoe Leg Hat Headgear Personal protective equipment
Yes, to me it looks full of dirt debris, and if so may be the cause of the water seepage as the intake is around that area.
· Administrator
View attachment 301440 View attachment 301441 View attachment 301443
Just an FYI the turn signal sounds come from the radio, so focus on the radio wiring.
· Administrator
1 - 13 of 13 Posts
