These things go into closed loop quite early. It's not a old car that needs a minute or so.A 10km commute at 50f barely gives the ecm time to come "on-line".
Monitor the eng temp next trip.
I'm only guessing here but the eng needs 175+ to allow the ecm to go into closed loop.
Have ya checked the tire pressure.
If your 14km commute is all stop and go you might not see much better. Now if you drive highway you should have no problem getting 650km (400 miles) from a 15.6 gal gas tank.i dont get more than 400km to a tank, thats 248 miles
I'll have to check into this more, because from what I have seen, the car doesn't go into close loop mode until the ECT hits 160 degrees F.These things go into closed loop quite early. It's not a old car that needs a minute or so.
I'd look into the usual suspects such as weather, tire pressure, any changes in usual driving routines/traffic, and letting other people use the car. Some folks are lead-foots that can't get good fuel economy if their life depended on it.
Without adding some highway to your route or eliminating stop signs/lights I really don't think you will see any improvement until the weather warms up.the 14km commute is all city but with a steady foot and all green lights usually
the car has the 1.4t and the 6 spd auto, i also follow that thread that you made on how to save fuel.
I checked this morning on my ScanGauge II. From a 33*F cold start with the car sitting in 33*F air all night, the car was in closed loop in 30 seconds. Not sure on coolant temperature, but likely wasn't much above 70*F or so, if that.I'll have to check into this more, because from what I have seen, the car doesn't go into close loop mode until the ECT hits 160 degrees F.
