1 - 15 of 15 Posts
Hey y'all. So I'm bored and looking at car parts. Zzp makes a rear disk kit for the sonic that's $400. Doesn't fit the cruze. I'd like to invite everyone to harass them into making one for ours.
I already sent them an email about this as well as motor mounts that don't completely ruin engine harshness.
Just a guess, if you were to buy that kit and some mounting brackets for the calipers that are OEM for the cruze, you could probably just screw everything together and go.
Discussion Starter #3
That's what I was ultimately thinking. Pricing it through gm parts direct is a pita, but doable. It says the hub mount is different though.
A lot of sonic guys have had nothing but issues with that kit.
First which rear tear end do you have on your Cruze?
Discussion Starter #5
Its a 2013 Lt rs. I know that there were two different axles used on that. Don't know what I have outside of that.
Well you need a zlink to do it.. I did mine for cheap yours could be more matters on how you get the parts
I believe I read some discussion before that you can convert to rear disk by using parts from a rear disk equipped cruze. May want to check into that rather than spending money on a aftermarket kit.
I Posted what's needed a month or so ago a few threads down.
Rotors
calipers (I have a set for sell $100 with lines and pads)
brake lines
backing plate
backing mount
cables
Brake pads
caliper bolts
Rotors
brake lines
backing plate
backing mount
cables
Brake pads
caliper bolts
Is that for people who don't have the Z Link axle or for people who do?
That's what I had priced out some time ago. All o.e. ended up in the 6-700 range.
Yea if you buy all new dealer parts it's in the high 700s you can buy a rear end for around 4 or less or find a part out like I did
Discussion Starter #15 (Edited)
Okay. I might have to holler at lkq sometime and have one shipped to my shop.
I should say after I get other things straightened out.
I almost did this some time ago, but then something surfaced about that not even working for some crazy reason.
1 - 15 of 15 Posts
