Pioneer.The North American Cruze's Panasonic sound system has a pair of speakers there.
They are 6x9" subwoofers, yes. As for being harness ready, I doubt they're there, but I guess you never know.Thanks gentlemen, I thought that may be the case.
I believe the 2012 SRi-V is fitted with the Pioneer system; however there is no branding on the speakers.
Holden must have had a budget cut that week!
If anybody has pics of the Pioneer system speakers on the rear shelf, I'd like to see what GM installed and if possible, where the wire harness is running in the trunk.
Looking at the cutouts, I assume they will be 6X9".
I'll now look for any remanence of an audio wiring harness down the back to see if we are wired for but no fitted with, as seems to be the case in Australia with our versions.
Cheers
Mark
Here you go:Thanks gentlemen, I thought that may be the case.
Cheers
Mark
This link may help:Cruzers
Thanks for the pics. When you have a moment could you please advise on the color code of both wiring looms.
RH looks like purple and green, LH not sure from the pic.
When I know the wiring codes I'm searching for, will advise if the car has a connection point or not at the back end.
Cheers
Mark
You could leave them both connected but the sound, power, and audio quality output would be crap. The factory radio only pushes 8-15 watts rms to 4 speakers. Cutting that power in half for the rear would kill your sound quality and probably your radio over time. Just buy a small 2 channel amp, a line out (adds rca to your factory radio), and hook them up that way. Its not that hard and the sound quality and speaker output would be tremendous vs trying to run it off the factory radio.This is an old thread....but maybe someone can help me. If I add the rear shelf speakers do I have to disconnect the back door speakers? A friend said I have to because the sound system wont take it
Depends on how you connect it. If you just connect them in parallel, yeah, you could blow the radio's amp. You could connect them in series, but then the volume takes a dive. If you use a add-in amp to drive them, then you should be alright.If I add the rear shelf speakers do I have to disconnect the back door speakers? A friend said I have to because the sound system wont take it
