Bump. Anyone who has installed them have pointers? The Whiteline documentation says, to uninstall the stock sway bar links, and put on the new ones. But there are no stock sway bar links. Where do hook the links into the suspension?
http://www.whiteline.com.au/docs/install_guides/Z5146_Z5160_Z5192.pdf
Is this the installation guide you used. Scroll down there is installation guide on the rear sway bar.
1. Raise the vehicle evenly and support with jack
stands then remove rear wheels.
2. Remove the 2 inner beam axle mounting
bolts on either side of the vehicle
assemble the swaybar link
mount placing the supplied 20mm (thick)
crushtubes between the beam axle mount
and the supplied swaybar link mount (spacing
the supplied bracket away from the floorpan)
using the supplied 90mm long bolts.
3.Place the supplied U bolts over the suspension
beam axle, then secure the swaybar loosely
using the supplied flat plates, urethane
bushing’s, bushing saddles and supplied nuts
Ensure the internal bore of the bushing’s are
greased liberally and distance between the
inside of the urethane bushings is
approximately 605mm.
4. Mount swaybar links in place making sure the
supplied small washers are between the nuts
and the swaybar. Ensure the swaybar links
are mounted into the softest hole on the
swaybar until you are
accustomised to the change in the vehicles
suspension characteristics.
5. Ensure all mounting nuts and bolts are tight
and secure before lowering vehicle down from
jack stands and test driving.
