1 - 14 of 14 Posts
recall #46000
GM has received reports that certain 2016 Chevrolet Cruze vehicles may have a loose connection at the battery negative terminal to ground stud. This condition may cause the engine to stall while driving, may prevent the vehicle from being started, or may illuminate the service engine soon light.
Safety Risk Description:
Add a washer on the ground stud and re-torque the nut to correct this condition.
Reactions: Tomko
Question - does anyone know if this is a Gen 1 or Gen 2 recall, or possibly both? The fix leads me to believe it's a simple assembly error vs. a bad part.
im not sure. i have the vin and build date/sheet and says april this year but i cannot tell if its gen 1 or two. i think gen 2 since my 15 gen 1 didnt get the recall
April would be right about the switch over time from Gen 1 to 2 at the factory. It's possible this is just a missed washer in the initial run of cars. I suspect this would be easy enough to visually check in your driveway.
new recall
It was on mine, but the recall was obviously completed before I bought it. If anyone needs help, let our team know. I can look into this more on my end as well.
Bought my Gen2 in May and got a call from the dealer today per this recall, so it may be specific to the Gen2 only
It is for sure the Gen 2. We have been doing the recall on our lot cars. All that happens is that a washer has to be added.
This sounds to me like a drive into the service bay, have an advisor check the washer and if it's not there the advisor goes and gets a tech to put the washer on. I've had this type of work done many times over the years. Other than an annoyance it's obviously just an assembly error.
Sounds like the old joke about having a part left over, but on an assembly line level. :grin:
I knew eventually id have to call one of the gen 2 drivers about the recall. well today was cruzetalks lucky day
1 - 14 of 14 Posts
