Hey all. I am coming up on my service for 97,500 miles and I am hoping for any input for other work that may be beneficial to be preformed that is not stated in the owners manual. The reason for this is that I use my car for work and downtime is not good at all and with the CTD's being newer and few and far in between, I was wondering if anyone had any unexpected maintenance done for their CTD between 100k - 120k.
Here is what I am looking to do at 97,500 (Turning over 90K tomorrow and will be ready for maintenance in a 1-2 months),
- Replace Timing Belt
- Replace Timing Belt Tensioner
- Replace Idler Pulley
- Replace Water Pump
- Replace Tires with another set of Michelin Premier A/S's.
- Transmission Fluid Replacement
Should I consider any other maintenance procedures to be done? Here is some other history on my car,
- Replaced battery 6 months ago.
- Factory brake's (Mostly highway driving and can change on my own)
- Had my transmission flushed and replaced with new fluid at 50K.
- All oil changes expect for the first two have been done by myself at or right around 7-7.5K with Amsoil and a WIX filter.
- Fuel filter has been changed as per the owners manual and drained of water at each oil change.
Any recommendations to have preventative maintenance done? I was considering to also have my starter and alternator changed at this service, but don't want to throw away money if they still have lots of life left. Thoughts and or advice? Thanks in advance for any and all feedback!
