1 - 2 of 2 Posts
I have replaced throttle body and pedal. As specified all over the net to replace, so i did. But still after all that it wont rev. Check engine light blinking then another with arrow pointing down is also blinking. Then yesturday i checked the ecu looks like it shorted out. Plastic from connector is melted.
So i got a newly programmed ecu today. Owner said he was messing with radio wires when this happen. So i removed the fuse for the radio for now to check out in a later date. Plugged in the new ecu but still problem didnt go away. Car just idles pretty.
Codes im getting
Po697
P2101
P2122
P2127
P2128
P2176
I tested the harness to the throttle body from ecm. Theres tps 1 then tps 2, is there suppose to be 5v showing on this or none until u step on the gas pedal? Because one is showing thats there is then the other it doesnt.
Any advise would be great.
Codes im getting
Po697
P2101
P2122
P2127
P2128
P2176
Welcome Aboard!(y)
Possible causes for P0697 include:
Open circuits and/or connectors
Defective or blown fuses and/or fusible links
Faulty system power relay
Bad sensor
Read more at: P0697 Sensor Reference Voltage C Circuit Open
Typically the causes for 2101 to set are:
Open or short in the circuit to the Throttle Actuator - likely
Failed Throttle Actuator - inoperative (mechanically or electrically) - likely
Failed PCM - unlikely
Read more at: P2101 Throttle Actuator A Control Motor Circuit Range Performance
A code P2122 may mean that one or more of the following has happened:
TPS not mounted securely
TPS circuit short to ground or another wire
Faulty TPS
Damaged computer (PCM)
Read more at: P2122 Throttle Position Sensor D Circuit Low Input
A code P2127 may mean that one or more of the following has happened:
Faulty TPS
Read more at: P2127 Throttle Position Sensor E Circuit Low Input
Possible causes for P2128 include:
Open or shorted circuits between the TPS, PPS, and the PCM
Defective TPS or PPS
Corroded electrical connectors
Faulty drive-by-wire actuator motor
Read more at: P2128 Throttle Position Sensor/Switch E Circuit High Input
P2176
Throttle Actuator Control System - Idle Position Not Learned
Read more at: P2176 Throttle Actuator Control System - Idle Position Not Learned
1 - 2 of 2 Posts
