Out of curiosity, did the dealer perform this?
http://www.cruzetalk.com/forum/25-s...al-coverage-14311-negative-battery-cable.html
Beat me to it while I was still typing. Anytime anything remotely electrical happens, I think all the regulars have come to realize the first question to ask is "Have you had the negative battery cable done yet?"Out of curiosity, did the dealer perform this?
If you're looking for a common thread, I'd start there. That's quite a load on the electrical system.turned on front and rear defrosters
Meaning additional electrical needs make the problem more pronounced…..same questions a good diagnostician would ask.Service Manager mentioned the neg cable as soon as I starting telling him what happened. That was the first thing that they checked. As far as having climate control on defrost and switching the rear defroster on being an electrical drain...? It's a 2 year old modern GM product, not a Yugo.![]()
Checked, or replaced?Service Manager mentioned the neg cable as soon as I starting telling him what happened. That was the first thing that they checked. As far as having climate control on defrost and switching the rear defroster on being an electrical drain...? It's a 2 year old modern GM product, not a Yugo.![]()
OK they may have checked the cable, but did they follow the instructions in the special coverage bulletin and replace the cable? The problem with the cable is known to be an intermittent one most times.Service Manager mentioned the neg cable as soon as I starting telling him what happened. That was the first thing that they checked. As far as having climate control on defrost and switching the rear defroster on being an electrical drain...? It's a 2 year old modern GM product, not a Yugo.![]()
I didn't say "you shouldn't do that". I was just pointing that that the two heaters add a strain on the system and could bring to light defective components. The car should be able to handle that, but then if everything was working right, the car wouldn't have died on you.As far as having climate control on defrost and switching the rear defroster on being an electrical drain...? It's a 2 year old modern GM product, not a Yugo.![]()
That's what I was thinking, how do you visibly check for a bad crimp in the cable? Might look just fine and connections look tight but your still left with the intermittent electrical issue. This is why GM extended the warranty on the part and just calls for replacement.And, I'll agree with the others. Unless the dealer has a later bulletin that shows how to check the cable, it should be replaced as per #14311 and not just "checked".
Take your car to a different dealership and tell them you are experiencing intermittent electrical issues. Make sure to mention stabilitrak warnings. The dealership you went to can't be bothered to apply corrective actions listed in existing TSBs - they won't bother to look at a new TSB either.Thanks for all the input gang. Rob: I understand what you're saying about the electrical load...I just couldn't resist the Yugo commentThe tech that drove it home overnight did indeed try to replicate the actions that I took, but to no avail. Combining everything I've gathered from others that have posted on various forums is what leads me to think that it is moisture/temp related. As far as the neg bat cable issue: My understanding from the SM is that the cable corrodes not at the battery but at the block/frame end of the cable. They did not replace the cable but did check to see that it was firmly attached and not corroded. I can only assume that they checked for proper crimping. I am still a fan of the car, but really am concerned that this is going to happen again. There is quite a bit of evidence out there that this is a known issue. I feel that GM needs to step up to the plate, acknowledge the problem, and issue a TSB on the throttle body.
GM has stepped up to the plate, acknowledged the problem and issued a warranty coverage for the battery cable for 10 years/120,000 miles to anyone who complains about certain symptoms. If the dealer doesn't comply, is that GM's fault or the dealers?I feel that GM needs to step up to the plate, acknowledge the problem, and issue a TSB on the throttle body.
What's wrong with the TB?issue a TSB on the throttle body.
I still find this puzzling. Here we are 5 model years into the life of the Cruze and we are still having to deal with Chevy service departments that can't/won't do the due diligence on customer problems. I'm probably flogging a dead horse, but I'm gob smacked given all of the support GM provides for service folks. TSBs, PIs, emerging issue web casts, tech support phone lines, web based learning classes, and the list goes on, but we still see weekly stories of service departments that should be avoided like the plague. How many posts have members directed the confused and shafted to visit another dealer? Even worse, we still have no way of determining which ones are OK and which ones aren't fit to change your oil. After 5 years, there seems to be no Chevy/GM program to improve franchised dealer service that is working. Climbs down off of his soapbox.Galimer: if you look at the thread that we have about the negative cable you'll realize how wrong your dealership was. Another incident like this can be EASILY avoided if you follow what every other member does. Please go to another dealership.
