Hello out there.. Wife burned through 3/4 of a tank of fuel. Had sudden onset of engine trouble, reduced engine power. She tried to drive it a couple of miles but was nervous about driving it the 8-10 miles home so I had it towed.
It had a change the fuel filter 0 life warning. I had changed it the 1st time at 46K, I'm at 72K now. I
1st 1000 gallons were mostly highway miles, I was aware that I was going to need to change the fuel filter soon due to reduced overall MPG. I changed the filter then checked codes and cleared them including reset of the fuel filter life.
P0869 = trans fluid pressure high, P087 = common low rail pressure, P088 = common rail high pressure, P128E =TCM? power control circuit 2 over current, B2AAA = body something.
After the codes were cleared I started it up and car revs up fine. I drove it down the road and i got the, change fuel filter 0 life warning, and it went immediately into reduced engine power. back to square one.
I thought maybe bad fuel? added 2 oz of diesel fuel additive then filled it up, let it run at idle for 2 hours. Cleared codes, reset fuel filter life, started to drive it up the road and I got the same warnings and reduced engine power. I drove it up the highway for 1-2 miles then back into the garage.
I have all the same codes back except the P0869. When it failed the 1st time my wife might have driven it a little harder than me if that might have any impact on setting the P0869.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
