It can be done. Fairly easily. I had my Manual Civic remote start, and that was 23 years ago. Not sure if you can do it with the factory remote start. I know there is a thread on it, because I wanted to do it to my Manual. I blew through 3 Manual Cruze Ecos, in 5 years and never did it to any of them. My 2017 Premier is an auto, so, naturally it has remote start from the factory. I know there are aftermarket alarms that actually allow you to remote start a manual, which require a sequence to be accomplished before you exit the car, for it to remote start upon your return. It has something to do with making sure it’s in neutral, which is obvious. Pulling the e-brake, and removing the key, which leaves the car running, you exit, lock the door and turn off the car with the remote. Or when you exit, and lock the door, the car turns off automatically.
Sent from my iPhone using Tapatalk Pro
