1 - 20 of 26 Posts
Hello, so my 2012 1.8l LS Cruze @ 130k miles just threw the "low efficiency" catalytic converter code. Chevy says I need a new one and it would be $700+ but I'm thinking of straight piping it because I'm getting rid of this car next year, is that possible without buying an exhaust manifold? It looked like the Cat was in the downpipes right after the upstream o2 or is that just fooling me and it's actually behind the down stream o2 in the middle of the car?
I would not recommend removing the cat, if you live in a state that does emissions testing. Cost of the repair may suck, but spread out over the next year its cheap.
I'm getting rid of the car early next year, I don't have to get smog done until the end of 2017/ early 2018. I really would rather remove the cats and be able to drive my car and enjoy it until I get my next new car early next year. I just don't want to spend $300+ on a new exhaust manifold if the cat is welded on to it.
Kinda crappy for the next owner to find out. Especially in California.
Sometimes those codes are just an O2 sensor that needs replacing. Cat really shouldn't be bad if the car wasn't misfiring or running with a CEL on for a lean/rich code for an extended time period.
There should be No reason that you would need to replace a Catalytic Converter this early in your ownership of said Cruzen unless you are dumping oil in the exhaust stream ..
I suspect that your problems are within the O2 sensors as they may have become worn and need to be replaced .
California's restriction on Emissions are the strictest within the lower 48 and should be adheared to !
Hey guys thanks for the concern but to clear a few things up, this car is and always will be a lemon due to having over 20 repair bills with some parts being repaired 4 times. The only reason I wasn't able to file was because unfortunately I had a very strict work schedule getting my career to start and had no time to deal with it.
I WILL NOT SELL THE CAR, IT'LL BE PARTED OUT NEXT YEAR. Chevy themselves wanted to buy my car off of me (because the engine) when it had 100,000 miles and I took it in for service they said the engine was in pristine condition and would like to make an offer. I refused because I didn't want some poor soul to deal with my car without a warranty.
The ONLY reason I want to remove the catalytic converter is to be able to drive my car without it refusing to start due to the clog(which is starting to hinder my acceleration and gas mileage by 2mpg) until early next year when I buy my new car, while having a bit of fun too.
*EDIT* Chevy just replaced the up and down stream O2 sensors last month btw.
I understand the laws in California and I'll gladly pay the fine or anyone else's fine if they get caught which is next to impossible.
Thank you again for the concern but I just wanted to know if the catalytic converter was on the down pipe and behind the downstream O2 sensor.
*EDIT#2* The car has 130,000 on it btw. I won't make it to 200,000 and it only got this far because I baby the **** out of it fluid and part wise but drive it like a bat out of **** every single day.
If sensor 1 is throwing the code, it's usually for the one under the car. That one could be removed and replaced with a straight pipe easily.
There are 2 cats on the 1.4, one near the exhaust manifold and one under the car. This is a fairly common setup these days, so I expect the 1.8 is similar. If the front one is clogged, which is more likely, you'd need a new downpipe.
Thank you sir, I guess it won't hurt to spend the $60 that my local shop wants to straight pipe the cat under the car, do most people straight pipe both cats or just the one under the car?
Can you get one from a salvage yard? Maybe something off of a 2015 with low mileage?
If the 2015 manifold fits my 2012 then yea its a possibility, ill look around and see how hard it is to pull it off of another engine
If the 2015 doesn't fit take a look at a 2011-2014 that was "totaled" in a rear end collision. The cats should be fine in this case.
Discussion Starter · #14 ·
Well my biggest problem is getting the CEL to go off after removing the cat.. I had him put it back on and the CEL went off for a few days and then came back on yesterday evening. The car started to bog down but I think that is also paired with my bad coil pack. The car is having issue after issue at 130k miles.. I've spent nearly $1500 in the last 2 months
Discussion Starter · #16 ·
I am going to part it out in the beginning of next year but I have to keep it drivable until then. I use this car to get to work because my truck(2500HD) would cost me $40 a day with my 30 mile commute each way in rush hour traffic... I'll spend $500 more for a total of $2000 in repairs and then that's it, I hope it lasts until next year because otherwise I'll let the first person that's interested tear the car down.
I killed a cat @ 67K and fuel trims were good according to all I asked to include servicing dealership.
I have a 2012, I am having the P420 code. replaced the cat under the car. When i pulled it off. All of the Catalyist material came out of the cat. It just poured out looked like a pile of rubble replaced it from the dealer installed it myself. Now i am getting the same code again. I am assuming the upper is bad now. Do they even sell these bolt ins ready to go for Cali cars? [h=2][/h]
1 - 20 of 26 Posts
