Replace stock gps unit for aftermarket mediaplayer/gps - cruze lt 2011
994 Views 3 Replies 3 Participants Last post by  Paasklaas
Hello,
Hope that someone can help me. I have a cruze lt 2011 with a stock gps unit. The Maps are soo old and updating is very expensive. For that reason I want to change it for an aftermarket one. Now I read somwhere that the stock gps unit has a different canbus than the stock radio unit. Is this true? As al the aftermarket ones were meant to replace stock radio units and not stock gps units.
Thanx in advance.
Regards
Dennis
1 - 4 of 4 Posts
It's $180 to update your OEM map database.
GM | General Motors | GM - North America Map Update - DENSO Global A - v.2016 | HERE
How much will a non-oem solution cost you?
Thank you both for answering. I can buy an aftermarket Android system for about 230 Euro's (250 dollars), but is has more functionality than the stock unit, for example bluetooth, so I would prefer that. But for that I need to know if I can replace the factory GPS unit with an aftermarket one. Probably it wil fit, but I don't know if the CANbus is different than the Cruze models without a factory GPS unir. The Cruze I have (bought here in Europe) is the Korean model I think? It does not have Mylink or something like that.
1 - 4 of 4 Posts
