You might have to reprogram it.
Programming the Power Windows
If the battery on the vehicle has been recharged or disconnected, or is not working, the windows will need to be reprogrammed for the express-up feature to work. Before reprogramming, replace or recharge the vehicle's battery.
To program each front window: 1. With the ignition in ACC/ ACCESSORY or ON/RUN, or when RAP is active, close all doors.
2. Press and hold the power window switch until the window is fully open.
3. Pull the power window switch up until the window is fully closed.
4. Continue holding the switch up for approximately two seconds after the window is completely closed.
The window is now reprogrammed.
Repeat the process for the other windows.
www.cruzetalk.com
That's what I did when I recently changed my window motor and assembly.
Express window up not working after regulator replacement
Hired mechanic through yourmechanic.com to replace driver's side power window regulator. After he replaced it, express up is not working. Window tries to go up then immediately goes back to where it was. Goes back and forth between 1/4 and 1/3 up. He tried to program it by holding the switch in...
