1 - 4 of 4 Posts
It looks like I'm going to be keeping the Cruze a little longer than what I expected, and I'm looking at doing struts and shocks.
For some of you that have been around for a while like @XtremeRevolution will remember that early 2011 and 2012 Cruzes prior to VIN C7239134 required replacement of the spring when doing struts. I've searched this forum high and low and I can't find these old threads explaining the changes, and concerns with just swapping cartridges into the old springs.
I thought Xtreme did a How-To on front struts, rather than his review at 100-500 miles which I found, but it didn't mention this issue.
Does anyone remember exactly what the differences were between the springs used on pre VIN C7239134 and the current GEN 1 springs?
While KYB and Monroe both have a strut for prior to VIN C7239134 and after, Bilstein B4's only have one part number.
If I go with the B4's would I need to buy new OEM springs as well?
I know the B6's are heavy duty, but that's a few hundred more for a car that doesn't see that much driving anymore. I'd like to avoid ending up ordering parts that don't work together if I order the B4's and use my springs.
My springs are in good shape, and were repaired late in 2011 on a 2012 build, prior to the service bulletins requiring spring replacement redesign.
Now 7 years latter finding all this info on the internet is harder to come by in searches. Anyone remember the details with this?
Thanks-
Carbon02
Thanks-
Carbon02
Spring length is the difference. The spring perch was moved. I believe they lengthened the spring on later models. I had my front struts replaced under warranty for clicking/knocking, and when I installed the Bilstein B6 HD shocks, they were a perfect fit. Bilstein's shocks will comply with the newer design.
Worst case, just order the replacement springs on gmpartsdirect.com or something and you'll be all set.
Thanks-
Carbon02
Probably not what you want, but this is what I have found so far:
Improving the 2011-2016 Cruze Handling & Suspension
[h=1]RE: TSB PI0645, why new Springs?[/h]
Thanks guys. I did find the Improving handling thread, but I didn't find the new springs thread. I remember it though.
You confirmed my suspicions. If I go with the Bilstein B4 I'll need springs. Since I'm considering doing this on a budget I'm tempted to consider KYB-G2, complete quick struts. I can get the complete assembly for the price of the G2 strut and new mounts, and I don't have to deal with the compression.
A bit surprised that Some manufacturers, Monroe, and I thought KYB had different assemblies for before and after the VIN break point. Why they wouldn't just use on part number, since the customer is installing what should be a matched spring and strut I don't know.
A side not to Balsirl-
Balsirl- I'm located one state over from you, are you finding a lot of Cruze GEN 1 in U Pull yards at a competitive price, or do you have a connection to get your seats? Guessing your getting a good deal pulling yourself.
I think there's only one U Pull yard near the twin cities and most of the new stuff is still 2005 and older. I snapped some dash vents in year 3, and I've lived with it since then. Maybe it's cheaper to just buy new, plastic in a yard can be brittle, unless you get it dirt cheap.
1 - 4 of 4 Posts
