Gen 2 is pretty scary so what about Gen 1 (Left-hand drive)? Even if as involved as Gen 2 described below:
- Are there any particular issues taking it step by step?
- Anything peculiar to Left-hand drive?
- Are special tools needed for Removal Step 10?
- Can the system be bled manually?
I have a 2016 Gen 2...
The clutch master cylinder is inside the car, but you have to remove the brake master cylinder and booster, the steering column and all of the pedals to replace it. ... (5hrs labor).
The car will have it's wipers, the wiper cowl, the metal at the base of the windshield, the coolant reservoir, master cylinder and brake booster, all 3 pedal assemblies, the steering g column, steering wheel, driver knee airbag and various bits of trim, and a dozen or more important electrical connections undone when performing this repair. There's also several clips and bolts that need to be replaced in addition to the failed part. ...
It's not a fun driveway project.
