Type: | power front disc, rear drum w/ESC (std) power 4-wheel anti-lock disc w/ESC (opt, std. on diesel) |
Rotor diameter (in / mm) and caliper type: | front: 10.8 / 276 vented; single-piston w/steel caliper rear: 10.5 / 268 solid; single-piston w/steel caliper |
Rear drum size (in / mm): | 10.5 x 0.5 / 268 x 12 |
Total swept area (cu cc; pad area): | front: 39.8 rear: 34.3 |
Why?Thanks am going in today to get them would you know any website that sells brake conversions kit I want to turn my rear drum brakes in to discs breaks like the front
As @MP81 said, the rear brakes only contribute so much, 20% from what I remember. But if you are determined the cheapest route would be to go to a Pick N Pull or LKQ yard, pull it yourself. The Z-Link from what I have read in other threads can be swapped for the beam axle. I would make sure to get every last nut and bolt as well. Looks like about $100.00Thanks am going in today to get them would you know any website that sells brake conversions kit I want to turn my rear drum brakes in to discs breaks like the front
