Repost: Negative battery terminal ground wire broken at connecting tip
10915 32
Note: This is a repost from the Gen 1Powertrain forums as the issue is electrical wires. Apologies for the repost
I have a 2011 Chevy Cruze LT and today while cleaning the negative battery terminal with a battery brush, the ground wire that is bolted to the terminal broke off. It was very flimsy and makes me wonder how it held up all along. Can that wire be replaced without going to a mechanic and I observed it goes under the fuse box. I don’t know the exact term used for that wire, but as it is broken I am not sure I can start the car. I could not find any videos or posts where the ground wire tip broke off. Any info and part number with pointers on how to fix would be appreciated
Adding the image should make the post clearer.
I am not sure if this wire goes all the way to the alternator or is connected to the fuse at the top the battery positive terminal
285614
1 - 20 of 33 Posts
Hi,
1. you may be able to buy a large enough "eye" crimp connector to fit over and crimp onto the existing broken one. Peel back and carefully cut away the shrink wrap to reveal the existing broken connector and shop for a connector that will fit over it. Buy a crimping tool, hacking this connection may lead to ground problems. I don't think the broken connector can be removed from the wire easily and without chewing up the wire itself.
fyi - If you cut the broken connector off the ground wire, there may not be enough length to reach the battery terminal. It looks like the connector and it's strain-relief(keeps wire rigid so it doesn't drape onto battery top edge-i think) is almost 2"
2. if you can't get a good connection with the 1st method, buy an identical eye connector as the broken one. Follow the wire down to the bottom corner of fuse box. The wire(harness) is held in place by a wire tie secured to the bottom edge of the fuse box.(pic) If you release or carefully cut the plastic wire tie(mine is grey), there may be sufficient additional slack in the harness to reach the battery terminal, then you can cut off the broken connector and crimp on a new one.
I have not done this repair, offering advice after looking at my negative battery connection and "eyeballing it".
285624
Hi,
Thank you for a detailed step by step help and I very much appreciate it. Like you said and as others have also chimed in, I will try out a ring type or eye terminal similar to the broken one. The gauge size is what I am debating between 12-10 AWG and 22-18 AWG and is it okay to replace with a larger size than the broken connector? Would it be fine to buy a similar size gauge wire ( gauge equal to the terminal connector) to crimp in case the length is too short. The length was another factor I was doubting and your pic on where the wire leads to helps a lot.
That's what I would do
Yes I am going to get a ring terminal and try out crimping like @12ecofamilycar suggested
One thought I had on this was to look for a wire that already has a terminal on it. You might need to buy something more complex and just cut off that piece. For example, I've seen some battery cables that had a small (eg, 12 gauge) wire with terminal already spliced into the cable. You could cut that section off and splice it onto the end of you broken wire and avoid dealing with crimping.
If you try to put a 22-18 gauge terminal on that wire, it may be too small. That wire is more like 12 gauge from what I can see.
My usual advice on this is to solder all connections, including the crimps. That's a sure way to avoid corrosion later affecting the crimp, or the crimp coming undone.
If you cannot solder, maybe you have a friend who can do it in exchange for a 12-pack of his/her favorite beverage.
Doug
I would carefully cut the old connector off while trying not to damage the wire too much (assuming you cannot replace the whole cable). If it is long enough, just cut the wire and restrip. I would not under any circumstance recrimp over the old terminal.
@touches @Blasirl
Yeah I should have tied the 'recrimp over a crimp' suggestion in with "hacking" but it sure doesn't read like that...my bad.
Not a permanent fix or 1st course of action, but as a last resort to get to the parts store and back before cutting the wire.
Reactions: Blasirl
Discussion Starter · #10 ·
Doug
That's a great idea, unfortunately the auto parts stores near my place namely O'reillys and Advance auto parts do not carry a simple 12 Gauge ring terminal and had no clue about battery cables with terminals attached. I have ordered 12 AWG ring terminals from Amazon and being my only vehicle, I am stuck waiting at home for these parts to arrive with the auto shops above ruled out. Like you said the stock wire seemed to have the connector already attached to the wire. I do have a 16 AWG fork connector but no sure if I can use them on this wire and if it can carry the required amps.
Yes sir, I have cut the connector and have stripped the wire and like you said if it is long enough I would just crimp them.
Attaching some pictures for any reference
285626
285627
This was the connector type and ring terminal just sort of disintegrated and came apart.
@touches @Blasirl
No problem at all, and your picture helped me a lot and any guidelines in this forum is a learning experience
Discussion Starter · #11 ·
The ring terminal was long enough to crimp and I connected wire to the negative terminal. After installing the battery, I get a P00B4 DTC service definitions not found error code. I am just tired of having one problem after another with this Cruze and being a student the costs to buy the tools and the replacement parts are taking a hard hit on my finances. Is this a major issue? Is it due to the ring connector crimping or any wrong sizes?
Someone on the forum who has real diagnostic experience would be better at helping you with the code but...
p00b4 is "radiator coolant temp sensor circuit high".
The sensor itself is easy to replace and $12 on amazon...there are 2 temp sensors; rtc(radiator temp sensor) and etc(engine temp sensor) 2 different part numbers even though they look identical.
One plugs into the coolant outlet(etc)drivers side of the engine, the other is in the passenger side edge of radiator(rtc). each has an electrical connector. Coolant has to be drained to replace them so you don't end up with a coolant mess.
I doubt it's anything to do with the actual connector you repaired, maybe having the battery disconnected for a while, but again, wait for a diagnostic expert type member to reply.
Don't despair! I thought I was the only 1 car household, it's a pain
Thank again for giving pointers on the parts, this has been a nightmare month, I replaced the valve gasket and installed the PCV V3 fix kit, changed the MAF Sensor, replaced the spark plugs,, negative battery cable terminal. Now these problems again!
I went to an auto shop to get a scan and they came up with the following codes:
P00B4
  • DTC Descriptor DTC P00B3 00 - Radiator Coolant Temperature (RCT) Sensor Circuit Low Voltage
  • DTC Descriptor DTC P00B4 00 - Radiator Coolant Temperature (RCT) Sensor Circuit Low Voltage
P0532
  • DTC P0530 03 - AC Refrigerant Pressure Sensor Circuit Low Voltage
  • DTC P0530 07 - AC Refrigerant Pressure Sensor Circuit High Voltage
  • DTC P0532 00 - AC Refrigerant Pressure Sensor Circuit Low Voltage
  • DTC P0533 00 - AC Refrigerant Pressure Sensor Circuit High Voltage
I just noticed my windshield wipers do not work and the windshield washer fluid does not blow as well. I am not getting a beep sound when I lock the doors of my car using the key.
Causes for this code may include:
Defective radiator or other coolant temperature sensor (CTS)
Dirty/plugged sensor pickup
Sensor O-ring/Gasket leaking
Broken or damaged wiring harness
Fuse ECM issue
Pin/connector problem (corrosion, melting, broken lock tab etc.)
Read more at: P00B4 Radiator Coolant Temperature Sensor Circuit High
Both temp sensors:
or
or
Discussion Starter · #15 ·
Fuse ECM issue
Both temp sensors:
or
or
Should I replace the sensors even if I don't see the AC Off due to High temp error message? Are the windshield wipers and no beeping sound when locked tied to this or is it another electrical problem I need to check?
Perhaps older battery? Maybe was it sufficient and recharged somewhat when car was being driven but lost too much charge when it was disconnected?
But... AC sensors, and coolant sensors, and weird wipers/wiper fluid pump, and door entry beep issue all within a day or so?
Should probably retrace the ground wire steps or anything electrical work to rule out a random mistake of some kind; think 'obvious 1st'- like-all connectors connected, or is something shorted and blew fuse(s), coolant spillage into a connector, or rats ate my fusebox...(sorry, you can see acorns under my fusebox in the pic), then move on from there.
Discussion Starter · #17 ·
Exactly that was my first thought, all these problems within a day and the windshield and horn beeping seems weird. My battery was dead and had to be recharged, it was tested today and came out okay. I will retrace the steps to the wires, but how do I check for shorted and blown fuses? Where can I find the wiper fluid pump and wiper motor to check for loose connections?
Should I as well get a new battery? I have ordered the sensors from Amazon after seeing your post, but I am still unsure as my wipers and door sensors being off!
You can check for blown fuses on the items that don't work in the fuse box, the fuse locations are listed in the box cover. There is a fuse puller in the box or use fingers. Get some replacements 1st, in case one(fuse) gets lost or falls into an unreachable space...
Check for loose connections only on the things you worked on 1st, then move on from there.
When you removed the battery, could have inadvertently caused a short but prob would have noticed that.
Replace it? If it's pretty new and checks out ok...idk but if it's 4 years old maybe check walmart price, I've had good luck with them.
Test them. If you don't want to remove them, at least test for continuity.
1 - 20 of 33 Posts
