Repost: Negative battery terminal ground wire broken at connecting tip
10914 32
Note: This is a repost from the Gen 1Powertrain forums as the issue is electrical wires. Apologies for the repost
I have a 2011 Chevy Cruze LT and today while cleaning the negative battery terminal with a battery brush, the ground wire that is bolted to the terminal broke off. It was very flimsy and makes me wonder how it held up all along. Can that wire be replaced without going to a mechanic and I observed it goes under the fuse box. I don’t know the exact term used for that wire, but as it is broken I am not sure I can start the car. I could not find any videos or posts where the ground wire tip broke off. Any info and part number with pointers on how to fix would be appreciated
Adding the image should make the post clearer.
I am not sure if this wire goes all the way to the alternator or is connected to the fuse at the top the battery positive terminal
285614
21 - 33 of 33 Posts
Test them. If you don't want to remove them, at least test for continuity.
So prob easiest way to test the coolant sensors while installed would be to buy a spare sensor connector w pigtail attached and connect multimeter to the wires? Have to find that connector, dealer parts dept may be easiest. Maybe amazon.
Morning cold engine here in the northeast at about 40 degrees, warm engine 200-225 approx.
my sensors are new but I'm interested in the test experience
Reactions: Blasirl
Discussion Starter · #23 ·
Hi, just checking in, any luck with your wipers, washer pump, entry beep?
Hello, firstly my apologies as I had to get back to work using the local bus and Uber and could not focus on my car. Your post on backtracking was a godsend and lifesaver. Today I did exactly like you mentioned and found a loose bolt in the engine fuse box!!. I tightened it and the fuse location chart given by @Blasirl was of immense help as I could track the wiper fuse location. I unplugged and blew off some dust and plugged them back in and started the car. To my wonderful surprise the wipers started working along with the washer fluid and the beeps returned and importantly the check engine light disappeared. I test drove before I could rush in and post it here and so far I didn't get the lights back on. The two sensors I ordered from Amazon and also heeding your advice I got a set of fuses as well have not been used. I may change the sensors but will defer it as I have had enough of time spent on this car and have to catch up with work. Only the power seat seems to be working erratically and it no longer raises up or down. I don't see it as much of a hindrance but will look into it at a later time. But more importantly thank you so very much for being there and helping me to get back on this vehicle. thanks to you, @Blasirl,@plano-doug and others who commented and without this forum I would have been lost for options to think and work. Thank you all once again
There are at least two recent threads on fixing the seat. I will see if I can find them.
EDIT:
Here is one and it refers to another in it.
Discussion Starter · #25 ·
EDIT:
EDIT:
Thank you once again @Blasirl . I saw the video about checking for the fuse, is that a circuit breaker fuse type? I am not sure if a standard fuse can be swapped in its place. From the threads I could not understand from the first reading on what to check, but I will go through again and try out the methods that have been posted
Fuse 13, 25A. I am guessing it is a dual element fuse. I could not find one for sale nor the part number.
From the video, I blew up the pic and got some part numbers.
Electronics Technology Electronic device Finger Electronics accessory
The 8-character (13898717) doesn't come up at the two GM parts sites I checked, but Google finds it at Amazon and eBay.
The Buss p/n on Google hits the same Amazon and eBay pages :)
The description says it's a breaker, but the mechanics of that are not clear - I don't see a lever. Perhaps the end pops out when it's thrown?
Or maybe it's the kind that times out and resets itself.
HTH.
Doug
Discussion Starter · #28 ·
HTH.
Doug
I searched in Amazon like '14V 25A fuse' and got a mini circuit breaker type, not sure if it has the same mechanics though
Both of these look just like the one in the video. The only downside is that I haven't seen any onesies - they're all 25-packs :(
Doug
I know this is an old post, but I was at a Pick n pull yard yesterday and scored a few of these automatic circuit breakers. When I pulled them I could not remember why i wanted them so this morning I did a search and found this video explaining them.
21 - 33 of 33 Posts
