1 - 8 of 8 Posts
Hello everyone. I am posting pics of the stock rims and calipers paint job that I completed a month ago. I had
a hiccup with spray painting a little too far away from the rim the first go around and that set me back a couple of
hours of re-sanding and painting. Well hope everyone enjoys!!!
WP_20150510_003[1].jpg WP_20150510_010[1].jpg WP_20150510_020[1].jpg WP_20150510_009[1].jpg WP_20150513_004[1].jpg WP_20150513_006[1].jpg WP_20150513_001[1].jpg
Reverend Red Bull
View attachment 155802 View attachment 155810 View attachment 155818 View attachment 155834 View attachment 155842 View attachment 155850 View attachment 155858
It can be a bit tedious painting wheels from a can. I did the wheels on my Jeep a few years back. 9 coats total (2 primer, 4 color, 3 clear) and took 10 cans of paint. I ended up having to re-sand and re-apply a primer coat in my effort as well. I never got to the spare, so hoping maybe to take that off and get to it before the summer is over.
Did you use caliper paint ? yeah the high temperature paint ..
I am going with a copper plate ............
Discussion Starter #6
Brian I used High temp engine block paint. good up to 500 F.
Hey Ger8mm sorry for late response but yea I have some pics and I chose blue due to blue is a mellow color and I like blue. I didnt want a bright sporty color. WP_20150810_001.jpg WP_20150810_003.jpg
Nice work! Looks great. How many coats of primer and paint did you do on each wheel?
Discussion Starter #8
First I sanded the rims down some with 1500 grit sand paper. After cleaning of course.
Followed by 2 light coats of primer followed by a third slightly heavier coat of primer.
In between each coat I gave it 15 min to set. Following this I gave each rim three coats of graphite. 2 light 1 more heavy
Then I wanted to make sure to give it plenty of a clear coat so I put 4 coats of clear coat on each one.
For the Rim inserts I taped off the whole face, used a razor to cut out the emblem, painted them graphite, pulled the tape off and
applied clear coat onto the whole cap.
1 - 8 of 8 Posts
