Hi guys
So, recently purchased Holden Cruze 2012 SRi-V JH Series II, 1.4L turbo petrol, second hand - last thread, hopefully (for now)
1 - During in automatic mode, I noticed when the car shifts gears, it's a little rough, like I feel a small jerk, like someone shifting in a manual poorly.
It's not smooth, essentially.
2 - Also, I noticed the gears generally shift around the 2500 rpm range or so?
But 2nd to 3rd gear happens around the 2000 rpm range - it's shifting early (compared to the others)
This is with normal conservative driving, not aggressive or anything.
3 - When I come to a complete stop, there's a little rumble in the car.
Something I noticed is when I come to a stop, say my instantaneous fuel usage is around 1.1L/100km, and one it's stopped completely, there's a little rumble in the car before that fuel usage drops to 0.8L/100km, for example.
Every time I come to a complete stop, a little rumble - sometimes it's quite evident there's a rumble.
I can change the gear to Neutral, or flick to the manual side, then go back to Drive, and it'll rumble again.
Creep forward a tiny bit and brake, and it'll rumble again.
Just weird - not normal is it?
Will changing the transmission fluid help smooth out the shifts?
Is it programmed to shift gears around those ranges?
What controls this stuff, can it be reset/altered?
Sorry for all the questions - just trying to get my car into tip top shape - as much as possible.
Thanks
Thanks
