Ok well I can't access the forum to read message it says no account by that name but my email address is linkedHey OP,
These are the same suggestions we made to you in our reply to your support request yesterday
Please don't hesitate email us directly if you are having issues with the site: [email protected]
hopefully it isn't the coil pack been replaced once already.Coil pack or PCV issue.
Oh yes and posting awayHoly crap you have resurfaced!
I'm a front end tech I work on ball joints and such not motorHey H3ll when did you become OP ?
Yeah I know I need a Hobbie .. I went out and bought 1 View attachment 167546
j could be on the note with his guess about the PCV ..but then again your a mechanic and I am sure that you will get to the fault down the line somewhere ..
It's mainly at wide open throttle It happens more when it's hot but I need to replace my spark plugs anyways I have coppers and they have 30k on themDoes it happen only under wide open throttle or are you getting a loss of power at a certain psi of boost?
Intake side of the turbocharger provides vacuum for the PCV system when the intake manifold (where you'd normally get vacuum) is under positive pressure.Also, check for the valve in the intake manifold that's under the line that runs from the turbo to the intake. Speaking of, what does that line do, anyways?
All the info is greatly appreciated I'm not too keen on motor work.Look on top of the ignition coil for oil. Also, check for the valve in the intake manifold that's under the line that runs from the turbo to the intake. Speaking of, what does that line do, anyways? Also, if you're tuned, gap to 0.028" if you didn't already know. Don't forget to oil the threads of the spark plugs. You said you were a front end tech, so, sorry if this is old news to you.
This ^^^. The vPowers are probably worn out by now.It's mainly at wide open throttle It happens more when it's hot but I need to replace my spark plugs anyways I have coppers and they have 30k on them
