1 - 9 of 9 Posts
Anybody with a SGII seeing their gauge keep clearing the numeric portion of the readout, and then bring it back, sort of like a resetting over and over? Mine has been doing this for a little while now. I thought it was a loose connection or something. I can be driving along and the numbers will go on and off every little while, but the parameters like NCR, MAP, etc stay illuminated, so it's not a hard reset.
Mine is good so far, nothing abnormal, but you should get a replacement if it's still in warranty
Sent from my LGMS631 using Tapatalk
No issues like that at all, might touch base with the manufacture, they have a phone number and was helpful when I purchased mine.
It's probably way out of warranty, but I will look into giving them a call or email. it does still work though, just keeps blanking out the numbers and then putting them back.
Anything else attached to the ODBII port? I wonder if something is interfering with the gauge's ability to get new readings. This might be an early symptom of something going haywire with the car's computer system.
Never noticed anything like this yet. I'll keep an eye on the gauge more often and see if I happen to notice anything.
Nothing else. I suspect maybe the cable or the unit itself might be going bad.
Might mention you are a moderator on a Cruze forum, I bought the scangauge recently partly because of your experience with the CTD and your miles. I use every angle I can come up with.. :grin:
Good advice, I hadn't thought of that!
1 - 9 of 9 Posts
