So after my recent attempt at trying to find a gauge for my CTD and trying an Edge Insight CTS with no luck (defective unit, last one in stock in my area), I decided to look around for a less expensive alternative. I came across ScanGauge and am currently working with the Development Engineer to get it working fully with the Chevy Cruze Diesel.
I have a custom unit that currently shows a Regen status along with various other working gauges such as Boost PSI, voltages, temperatures, etc. He is working on adding other gauges such as Soot Grams and DEF level gauges. It is quite a bit cheaper than some of the alternatives, such as the Edge Insight CTS and is capable of showing more information than most other gauges. It is able to read and clear codes, has trip monitoring, fuel consumption statistics, the works. It's quite an impressive and compact unit. I'm very pleased with it so far.
If you're interested in this unit,
check out the website to read up more on it. I'll be keeping this post updated regularly as more gauges are enabled for this unit.
I just thought you guys may be interested in this as I've seen some posts from people asking about gauges. Below is a screenshot displaying some gauges and a performance video.
Regen Status (shown as RGN), is indicated in numbered states
0 = Off
1 = Active
2 = Completed
3 = Inhibited
The others are pretty self explanatory.
TFT = Transmission Fluid Temperature (Shown in Fahrenheit)
STM = Soot Mass in the DPF (Shown in grams) (Not sure on the accuracy of this. I'll have to see how it changes when the car enters a regen)
Soot Mass gauge is inaccurate in photo. Should be showing 12-13 grams.
July 28th EDIT: Just received a reply from the Development Engineer. He's worked out gauges for the following:
Exhaust Gas Temperature 1 (Degrees Fahrenheit) Reporting accurate data.
Exhaust Gas Temperature 2 (Degrees Fahrenheit) Reporting accurate data.
Exhaust Gas Temperature 3 (Degrees Fahrenheit) Reporting accurate data.
DPF Soot Mass (Grams) Reporting accurate data.
DEF Level (%) Reporting data. Unsure of accuracy
DEF Range (Miles) Reporting data. Unsure of accuracy
Average DEF Consumption (g/km) Reporting data. Unsure of accuracy
Remaining DEF in Tank (lbs) Reporting data. Unsure of accuracy
DEF Temperature (Degrees Fahrenheit) Reporting data. Unsure of accuracy
Some of those, mainly the DEF readings, I didn't even think the vehicle would read at all. I'll be testing these out shortly and will let you all know how it goes!
EDIT: So all these gauges report data and they seem to be functioning as intended. I'll need to wait for a regen to occur so I can see how the data for the Regen Status and DPF Soot Mass behaves.
July 29th EDIT: I've received some more gauges from the Development Engineer. I'll post them below and some pictures showing the gauges on the device itself.
Intake Air Temperature 2 (Degrees Fahrenheit) Reporting accurate data.
Intake Air Temperature 3 (Degrees Fahrenheit) Reporting accurate data.
Charge Air Cooler Temperature (Degrees Fahrenheit) Reporting no data
Relative Humidity (%) Reporting no data
Extended MAP (PSI) Reporting no data
Transmission Fluid Temperature (Degrees Fahrenheit) Reporting accurate data.
July 30th EDIT: I received 2 more gauges. These ones will come in handy if they work! I'll test them tomorrow.
Engine Oil Pressure (PSI) Reporting accurate data.
Torque Delivered (Ft-Lbs) Reporting accurate data.
EDIT: Tested the 2 gauges above and they seem to be reporting accurate data!
August 3rd EDIT: 3 more gauges available that I will be testing tomorrow.
Torque Converter Clutch Slip Speed (RPM) Reporting accurate data.
Gear Ratio (x.xx:1) Reporting accurate data,
Current Gear (13 = Neutral, 14 = Reverse, 15 = Park, 1 = 1st gear, 2 = 2nd, etc) Reporting accurate data.
August 4th EDIT: A couple more DPF related gauges I will be trying out tomorrow. They may or may not work. Let's hope they do!
Distance Since Last DPF Regeneration (Miles) Reporting inaccurate data.
Number of Completed DPF Regenerations (#) Reporting accurate data.
