1 - 19 of 19 Posts
Last week I replaced the lower radiator hose on my girlfriend's 2014 LS 1.8L. That stopped the previous leak, but now it looks like I have one coming from the thermostat housing. It looks like the housing is GM part #25199824. Are there any other parts that connect to this that I should also consider replacing preemptively? I just don't want to be playing whack-a-mole with the cooling system if I can help it. I've read that the reservoir itself is something people usually replace, but I don't currently see any leaking from that area thankfully.
Thanks.
Thanks.
On my 2012 1.8, I found the part you identified leaking where it joins the head.
I also found both nipples on the reservoir cracked and leaking, requiring it to be replaced. On the reservoir, the cap is also known to leak, requiring a new o-ring, or just get a new cap - it's probably easier to source.
Lastly, on my 1.8, there is an "oil cooler pipe" from the water outlet / thermostat housing which runs under the exhaust manifold. I have part number 25194218 for it, but I'm getting "does not fit your 2015" messages when I check it against your info. There are o-rings on each end of that pipe which you will want to replace. Again, it's easier to get a whole new pipe than try and find the right o-rings (IMO). Given the "does not fit" messages, this may be something you want to get at the dealer parts counter, to be sure it's the right part for your car.
HTH.
Doug
[EDIT]Update: gmpartsgiant.com says 25194218 is indeed the correct part number for the oil cooler pipe on your 2015.
the water pump is also notorious for coolant leaks. i've now had to replace the thermostat housing, lower radiator hose, and water pump, but my coolant leaks are now gone! at least for the time being..
Is this a 1.4 or 1.8? The 1.4 is notorious for leaks, but we're talking about a 1.8 here.
Thanks.
Discussion Starter #9
On the 1.8, the thermostat housing is closer to the driver's side.. nowhere near the water pump. But it looks like I will be replacing the pump as well, because this morning I could see that coolant had dripped from the passenger side over night (unlike the previous morning, where I could see coolant had pooled right underneath the thermostat housing). The lower radiator hose is new, and it does not appear to be leaking like it was before. So it's gotta be the pump on that side and the thermostat housing on the other. Frustrating, but thankfully the engine and transmission still seem to be in great shape. So hopefully these repairs will be worth it in the end. I'll post an update hopefully next week.
Regarding the water pump, is removing the upper engine mount actually necessary? I've seen people do this in videos, but I can clearly see and reach the pulley bolts right now. I need a shallower torx bit driver, but I can reach them it seems. Thanks again.
Keep in mind, on the mount shown, some of the bolts must be replaced, per the manual. But some can be re-used. So, if you end up needing to remove the mount, maybe you can get by removing just the re-usable bolts.
HTH.
Doug
Discussion Starter #11
Yeah, it seems like the mount is completely above the belt, so hopefully I can get away without having to remove it.
Thanks Doug.. do you know if the manual specifies the torx bit sizes for the pulley and the pump itself? Looks like I need a stubby set of bits.
I don't think the sizes are in the manual - that would be too helpful :)
Seems like the ones I used (doing a timing belt) were all ⅜" drive, about 1½ to 2 inches long, so not very stubby.
HTH.
Doug
Discussion Starter #13
For reference, here are the parts I ordered from RockAuto.com:
2014 CHEVROLET CRUZE 1.8L L4
ACDELCO​
25194218Oil Cooler Line
$ 27.79​
$ 0.00​
1​
$ 27.79​
ACDELCO​
252947 (252-947)Water Pump
$ 48.79​
$ 0.00​
1​
$ 48.79​
ACDELCO​
1581816 (15-81816)Thermostat Housing / Water Outlet
$ 67.99​
$ 0.00​
1​
$ 67.99​
GATES​
K060609Belt
$ 16.08​
$ 0.00​
1​
$ 16.08​
Shipping​
Ground
$ 7.99
Tax​
$ 10.04
Order Total
$ 178.68
[TD] [/TD]
[TD]Part Number[/TD]
[TD]Part Type[/TD]
[TD]Price EA[/TD]
[TD]Core EA[/TD]
[TD]Quantity[/TD]
[TD]Total[/TD]​
Discussion Starter #14 (Edited)
Well unfortunately, one of the water pump pulley bolts won't come off. I was able to crack the other 2 loose, but as soon as I put my torx bit in the third one, I could feel that it wasn't seating right.. either someone already tried getting off before me or it had just corroded.
Any tips for cracking this last bolt loose? It's in a tight spot, so the options seem limited.
A couple thoughts. If the bolt has any shoulder on it, and there's room around it, you might try one of the extraction sockets that are made for rounded bolts. The sockets have sharp spirals formed which cut into the bolt shoulders to grip it.
The other idea is to get a slightly larger torx and hammer it in. In fact, you might start with the one you have and see if tapping that into the star hole improves the grip any.
Typical torx sets go by increments of ~5, so your next size up may be too big - you might need to scrounge some tool places looking for one that's just a tad bigger than the "correct" size. the idea is that, if the hole has been hogged out a bit, a slightly larger torx bit, with the help of a hammer, might still be able to get a good grip.
In shops, when a bolt won't turn, they often put a torch on it to heat it up, then turn it. I have used that on a brake hose with success. Propane torches are pretty common. Some folks prefer acetylene because it's hotter, but that pretty much implies welding gear.
After that, you're looking at drilling the head off, then hoping you can get the remainder out with vise grips. If you can't get a regular drill on it, they make right angle adapters for drills which might be an option. In fact, they now make right angle drills. Perhaps you can rent one rather than purchasing.
After that, about all that's left are sawzall or cutting torch :)
Doug
Discussion Starter #16
Doug
Thanks. I should note that these bolt heads are already round..to remove them requires a torx bit driver, not a socket (which I would be using on the water pump mounting bolts). But maybe an extractor would still work. I can't drill or hammer because there's only 1.5 inches of clearance between the bolt head and the metal framing.
Discussion Starter #18
A 1/2" extractor socket did the trick. I put some vice grips on it and used a screwdriver to lever the socket and push it against the bolt heads. Hopefully I'll get everything replaced tomorrow.. nothing like the holidays to delay mechanical work :p
Discussion Starter #19 (Edited)
Ok, it hasn't leaked on short trips made over the last week, so I'm going to call this a success for the time being. What caused it to leak in the first place is still unknown, so we'll see how it goes. If it happens again, I'm going to get the exhaust tested for leaks. Here is what I replaced:
1. The lower radiator hose assembly. On the 1.8, this is a hose with a temp sensor built into the plastic quick connect fitting that goes to the radiator. This was where the original leak was. To replace that, you definitely need some hose clamp cable-type pliers to remove the clamp at the engine. You also need a radiator hose pick tool like this:
The connection at the engine side is very difficult to reach, so you need something like that (or you have to cut it off, which is more risky imo).
2. The water pump. Turns out that you do not need to remove the motor mounts, as shown in some videos floating around YouTube. You just need to remove the front-passenger wheel bay cover. I would strongly recommend removing the water pump pulley bolts with a 1/2" extractor socket as mentioned above (while levering it against the bolt heads with a long screwdriver or a small pry bar). I would not even bother trying to remove them with a T40 torx bit.. not enough room, and they easily get stripped. I replaced the original pulley bolts with some hex-head bolts that were the same length and thread size, and added blue Loctite to the threads. The belt tensioner can be loosened with a 19 mm 12-point socket and a long breaker bar. Then you just shove a pin or an allen key in the hole to hold the tensioner in place while you remove the belt. If I recall correctly, the mounting bolts for the water pump required an E-8 or E-10 torx socket.
3. I replaced the drive belt itself, since coolant had been leaking all over the old one.
4. The thermostat housing. This again required a hose pick tool to remove the heater hoses, and an E-8 torx socket to remove the mounting bolts. I did initially have a leak at one of the hoses after I replaced it, but I noticed the clamp wasn't on there quite straight, and it was close to the end of the hose.. so I moved it downstream about 1/4 inch. Seems to be fine now. I also replaced the gasket for the oil cooling pipe that connects to the thermostat housing. To disconnect the oil cooling pipe requires a torx bit driver (thanks again to Doug for pointing that out). I don't recall what size bit is required for the bolts for the oil cooling pipe, but I bought this set (and one of them did the job):
Note that I did not replace the oil cooling pipe itself, because it requires the exhaust manifold to be removed. Since I never saw any leaking from underneath that area, I decided to just replace the gasket only. So far, so good.
Thanks again for the responses.
1 - 19 of 19 Posts
