2011-2016 Cruze 1.4L PCV Valve Cover/Intake Manifold Issues
Video:
I made a video to help better explain how this whole PCV system works to supplement this article.
Overview
I find myself having to explain this issue to someone almost daily, so in the interest of brevity, I'm creating a...
Hi all,
Recently, I've started noticing a few unusual feelings while driving my car, including: skipping 2nd gear (revs only to about 1200rpm after 1st, quickly shifting, dropping to around 900rpm when shifting, and then jumping up to 1700rpm after "skipping" all with my foot hardly on the...
I have a 2014 lt. It had the typical pcv issue rough idle same as always so I changed the valve cover. Then it started spewing oil out of the valve cover. I tried another one I thought it was warped but the same thing happened. So I just changed the intake and I broke the flimsy corrugated pcv...
Hello I am brand new here and need some advice. I have a 2014 Cruze Ltz and the transmission fluid has never been changed. The manual states it should be done every 45000 miles. Since it is so far past the maintenance time should I change the fluid or should I just leave it alone? I am scared I...
Hello! I read through some threads ahead but didn't really find what I am looking for as far as "power loss explanation. I have a trifecta tune and normally would get to 23-24 pounds boost under full uphill acceleration in performance mode. I reflashed my car and suddenly I cannot get over 10...
