1 - 2 of 2 Posts
I recently took my Chevy Cruze 2015 54000kms for servicing, basically oil change, cabin and engine filter change and tire rotation. Less than 400 KMS after that now the car has developed weird problems. It shakes badly when I brake or idle, Stabilitrak system service notification appears, the orange engine light is turned on, remote OnStar commands don't work, engine makes screeching noise when driving, gear transmission is very rough and disorganized and abrupt. What's going on?
Perhaps check for lug nut looseness, check oil level, and take a basic look under the hood.
The shimmy and the stabilitrak may be related to a loose wheel perhaps? The check engine light and engine noise may be related to low oil/leaking oil? The transmission issue I'm not sure of and the OnStar issue I'm not sure either if all they did was oil change, tire rotate, cabin filter.
1 - 2 of 2 Posts
