The car uses an advanced charging system. In order to save fuel, it tends to lower the voltage when you accurate, and raise it when you coast. It's not the old "14.4V all the time" type system.
That said, I'm not sure what's going on. Are you able to pull a code? Have you had the battery load checked?
